JON BOAT TUNNEL DESIGN/ EXTENSION
czuniga
HELLO TO ALL
RECENTLY HAD A CUSTOM TUNNEL WELDED ON A 2072 JON BOAT.
HOWEVER TUNNEL HAS LEFT FLUSH WITH REAR OF BOAT SEE PICTURES. I
HAVE BEEN HAVING SOME OVERSPLASH AT TAKE OFF AND MY PROP CAVITATES FROM
TIME TO TIME. IM THINKING OF A FEW MODS TO MY VESSEL AND IM SEEKIG ANY IDEAS FROM
ANYONE WITH A SIMILAR SETUP. I HAVE SEEM ON OTHER VESSELS WHERE TUNNEL EXTENDS A FEW INCHES OUT THE BACK.
ONE OF MY DEAS IS TO WELD A PLATE ACROSS THE TOP TUNNEL . SPONSOON TO SPONSOON HOWEVER SHOULD I WELD THIS AND AT ANGLE OF SHOULD I WELD AT A 90 DEGREE SEE PIC ( OPTION A OR B
OPTION 2 IS TO JUST ESTENT THE ENTIRE TUNNEL A FEW INCHES ABOUT AROUNT THE TUNNEL,
I APOLIZGED FOT THE CONFUSION ANY HELP WOUL BE APPRECIATED.
THAKS
Have a couple pics, here one on my 1648.
tunnel extension works pretty good on jet drives; not so much on prop drives. You'll really want to play with it before adding an extension to your tunnel if you're using a prop. Tunnel/prop never impressed me; at least not like a tunnel/jet
MOST TUNNELS I HAVE LOOKED AT ONLY EXTEND A FEW INCHES OUT THE BACK. IM THINKING ABOUT COMING OUT ABOUT 5 O 6 INCHES DUE TO THE SIZE OF THE BOAT.
THANKS FOR THE INFO
will let you guys know how it turns out
Look up Ott Defoe River boat on YouTube if you don’t know what I’m talking about. He has a pretty cool river boat with a prop and a huge tunnel.
