Installing a raised floor in a 14' semivee. How to attach angle to ribs in the hull?
RaisedByWolves
Bucks county PA.
Last year I picked up a 1980 Mirrocraft semi vee and Im getting around to adding a floor to mount pedestal seats rather than the benches.
I have bought some 1 1/4" and 1" aluminum angle and Im getting ready to cut it for the install but Im undecided on how to attach it to the hull.
Ribs are every 9-10" and I plan on using the 1 1/4" in the back to better support my svelte 300lb frame and do the rest with the 1" with 1/2" flooring through out.
What is the best way to attach?
Do I need mid span supports?
Special mounting base under the floor to mount the pedestal bases on?
This will be for a lake boat and I have purchased helm rated pedestals for both seats.
