Float pods , hinged
Sparky508
Float pods , hinged
Post by Sparky508 »
I had found where a gentleman had done this somwhere. So on the shoulders of giants, here I go.
I want to add a little flotation to my jon, I fish alone a bit, and even with batteries and gear up front, she sits a bit low when I'm in the rear fishing. Also planning on putting a 4 stroke 9.9 on her so a little more weight coming soon.
All the reading in the world says, hang em wrong and loose speed, or loose flotation, cant have both.
So with these mounted on actuators, I can get a bit of throw out of them. Buried for max flotation, and maybe a little braking action for trolling with my main motor, and raises up with a pretty nice upward angle to keep em from digging and letting me get the bow up. Water skiers seem to love creating a huge wake for me to cross as I motor in at the end of the day on a couple of my favorite lakes.
One of my questions is will this gap on the side of the pods cause me fits? The bottoms will have that angled aluminium to make a "smooth" transition from the hull to the pod, and hide the hinge a bit. Thinking a piano hinge will hold em allright and if not can be replaced with something more better. Have some 1/4" AL plate to stiffin up the pod for the actuator and hinge mount, so hinge would be weakest point I believe.
What do y'all think?
thedude
2
Float pods , hinged
Post by thedude »
This seems like overkill. If you can provide more info about your setup and some pics, there is a much better chance you can solve your problems without this.
But from an pure engineering perspective, I'm extremely curious!
Sparky508
Float pods , hinged
Post by Sparky508 »
Lowe 1436 riveted jon. Pics is before bow mounted trolling motor with remote steering and speed control. Control box is for steering, speed and pod actuators.
Might be overkill, but its fun! Parts are cheap, well the pods were 300bucks, and that's half what I paid for the boat!
She runs shallow when balanced, 2 people. I can pole through 8-10" of water.
Alone, the trolling motor likes to chop water when I lean over to deal with the port side downrigger. Pods ought to help with that too.
CedarRiverScooter
5
Float pods , hinged
Post by CedarRiverScooter »
Nice idea! You might want to connect the top better, so if you hit something sideways it won't tear off the hinges.
Sparky508
Float pods , hinged
Post by Sparky508 »
Cedar, do you mean the actuators to the pods? Or the hinges to the pods?
The hinges which have a 1/4" pin, and the actuator will be mounted to a 3/16" AL plate? that will be bolted to the pod to spread out the load. Is that what your saying?
Also I guess if the hinges broke, that would be the best outcome. As far as sacrificial parts, I'd rather that ripped then anything else.
Thinking 1/4-20 hardware all around. 3m5200 between parts to keep em dry.
CedarRiverScooter
5
Float pods , hinged
Just saying that if it can break off, it will happen to me. We boat in adverse conditions & have been pinned against a log jam with 10 mph current, etc.
LDUBS
3
Float pods , hinged
Post by LDUBS »
Huh kind of a double duty. If I understand your objectives: At just about any speed at all these would act as hydraulic trim tabs. At rest or slow trolling they would be for floatation to trim the boat more bow down.
Well, it is kind of different but hey, they laughed at the Wright Brothers, so who knows, maybe you have something revolutionary here. I look forward to hearing how they work for you.
Have Rod - Will Fish
Sparky508
Float pods , hinged
Post by Sparky508 »
Yes sir exactly!
Like trim tabs that provide flotation. The guy who I saw do this had a larger boat, never did see how it worked out.
My concern though is will that gap between the side of the hull and the pod cause any issue?
Sparky508
Float pods , hinged
Post by Sparky508 »
Yes sir exactly!
This is the pod and its lower position so not at speed, but even up it would have about an inch or so of gap.
CedarRiverScooter
5
Float pods , hinged
That gap could cause some turbulence. Maybe install an overlapping panel? You can temporarily attach it with adhesive caulk. Doesn't even need to be metal.
maintenanceguy
1
Float pods , hinged
Post by maintenanceguy »
I don't think that gap matters. If you're moving slow, it's not important. If you're moving fast, the side of your float pods will be in an empty space and not in the water.
I actually like this idea. A combination float pod and trim tab. I'm not sure that it will turn out to be useful but it's a cool experiment. Let us know how it works.
-Ryan
Sparky508
Float pods , hinged
Post by Sparky508 »
After much hand wringing, I managed to get the access holes and covers done today. At a stopping point until my hinge gets here. ( Ended up with a steel one instead of an AL hinge.)
The access covers really stiffen up the top. It will also be where I mount the lower end of the actuators to the pods. There bolted to a piece if angled aluminium that is tapped, and held in place by 2 through bolted 1/4-20s . Probably do the same thing to mount the hinge, but I'll through bolt the whole hinge, and skip the tapping part.
Float pods , hinged
Post by richg99 »
I just bumped into this thread.
At one time, I put Smart Tabs on a Carolina Skiff. I was very happy with the results.
Your approach is similar, except for the added pods. I surely don't know, but my gut feel is that the pods will get torn off if put under any real speed...configured the way I think they are set up.
Now, if the hinge were on the Bottom of the pod, there wouldn't be any dangerous gap to worry about.
It is great to see such experimentation. Go for it.
DO YOUR PART, STAY APART!
eeshaw
Float pods , hinged
Post by eeshaw »
I put a set of pods I made on a 1436 just to see how the boat would react to them but mine where through bolted to the transom and stationary. My own feeling about them having the gap is that when you're underway the gap will create an area that tends to suck the water in causing drag, to me that's why it's not done commercially. I've been kicking around the idea of putting full size pods on the back of my 16 foot flat bottom but make them as tall as the transom. This will give me additional flotation and make it possible to mount a larger motor if I want and increase load carrying capacity. Also, when you shut down the motor quickly from being underway they will help keep the water from trying to come over the transom, acting like a bobber.
If you wanted to, you could try hinging them at the top instead of the bottom, that would let the water escape easier. You could attach some rubber between the side of the pods and the transom on each side to keep the water from trying to collect in the gap area. I don't think the pods will increase the stability side to side any appreciable amount though.
Sparky508
Float pods , hinged
Post by Sparky508 »
Got a little more done. Just need that damned hinge!
