drain plug in floor of rich line jon boat
luck
awendaw sc
i have a 1960 richline aluminum jon boat with a threaded floor drain and id like to know where i can get a replacement drain plug
its about 1" in diameter
If like the brass one pictured below, at just about any hardware or plumbing store. If you get one from a boat supply place it will probably cost 4 times more for the same thing. Haha
Hi,
I know this is an old thread but haven’t seen it mentioned after searching the site. Try this link for a floor drain plug. I looked for a while and finally found this one that worked perfectly for my Richline. Hope this works for you.
https://www.amazon.com/VINTAGE-CRESTLINER-NEOPRENE-WASHER-INCLUDED/dp/B00L4G365K
