New to me Boat :)
pbw
Louisville, Kentucky USA
Got it on E-bay for 760 dollars, I bid thinking it would go for way more. The trailer and trolling motor if purchased new would cost around 900, trailer $320 out the door new, Tm I found on bps for $599. My thought was if I got it for under 800 dollars since the Tm and trailer are new its a good deal and if the boat is crap at least I still come out with an okay deal. The boat is in good shape the decking looks pretty nice. I'd like to remove some of the wood supports for alum, remove the middle seat and expand the front deck.
Details:
Harbor freight Jon boat trailer, one month old. ( Esquire posted about these )
Trolling motor is new MK 55 LB Thrust with auto pilot and foot control.
Batteries: Two Deep Marine Batteries CA: 660 CCA: 470 said to be one month old.
1987 Grumman 14 ft, 38 inch bottom Jon boat
I'll post more photos later after work I got home late last night from picking her up, just snapped a quick pic with the blackberry while waiting on the people I commute to work with.
Towed her about 3 1/2 hours last night the trailer pulled better than my Tractor supply store utility trailer.
*edit moving photos
Just looking I'm going to need some thoughts on the rear decking so I can operate an outboard, right now I can't even hang one on it due to the decking.
Nice rig! Hard to tell in the pic, but isn't there a rear lid where your battery(s) are stored? You might have to do some trimming on the lid if possible to mount the motor.
I sure wish my garage was as squared-away as yours! 8) . Mine needs a good cleaning (as in take some stuff to the dump).
esquired said:
Dude do not worry about that trailer in Louisville - heck they do not even have vehicle inspections right?
I've never heard of a vehicle inspection. The trailer is titled as "14-15 boat trailer" doubt I could get a ticket.
Here is what I would do to that boat.
First of all, you shouldn't tow that boat a mile the way it is, if you attach a motor. The bunks need to extend a couple inches past the boat, on ANY boat. The outboard pushes down on the transom, and that is where the most support is needed. 2 ways to do this. 1, make the bunks longer. 2, go to a welder, and extend the tongue. Personally, we would do the second. On any trailer, too much tongue weight is better than too little. On jons, there really isn't such thing as too much tongue weight. Therefore, by extending the tongue, and sliding boat forward, you get the axle farther back, and it will tow better, especially when adding an outboard.
As far as the boat, your bow deck is probably pretty good. I don't know your style of fishing, but for many people, that is enough deck. Then, I would lower your seat amidships, and use that while running the outboard. Trust me, you aren't gonna want to sit that high while running.
Then, that aft deck needs a bit of work. I would shorten it a bit. Then, have an adjustable height seat pole, so while fishing, you put the extension in, and then while running the outboard, you drop it down. It is a real pain to reach down for a tiller. You will find yourself sitting on the deck to drive before long, if you don't. You will have to shorten the deck, as you won't be able to reach the tiller, if you put a seat at the front of the deck. Find the aluminum factory installed bench seat. Personally, I wouldn't extend much farther forward than that. They are placed there for a good reason. You can extend forward on the sides, but the middle needs to be open for your legs. Having them extend forward on the sides will actually help you more than you think. You rarely will use the area directly forward of the seat for fishing, so from what I have found, that is the best design.
Good luck, and keep us posted!
Alright, just reread your first post. Disregard what I sayed about your bow, and midships deck. You seem to have a good plan there. But, I would recommend finding a way to use a lower seat while driving. May want an adjustable height post, and the bow guy just sits backwards. Good luck!!
Okay detailed photos now where is the SUN LIGHT? Freaking time change and winter! I'm going to use this thread to detail my mods unless Jim wants me to move it else where.
and ps pic of the other side of my garage I like my garage's empty :eek:
*edit moving photos :eek: to gallery
I recall (a looong time ago) that Ky had vehicle inspections, and a dang sticker for it that went inside your windshield.
Wow, that first picture just didn't do justice. That is clean, and well cared for. But, I still stand by my post on what you may want to do to it. Just my 2 cents worth, take it or leave it. :D
I like the river anchor system - I fished on a float trip where they used chains to drift anchor for bass.
One of my spring projects will be to add that!
I don't know too much about drift anchoring :eek:
:shock: Brings to mind what happened to me about 3 years ago at Ky Lake while using the Tracker. It was windy and I noticed we were drifting, even though I had the anchor out. Looked over the side of the boat and saw my polypro anchor line floating freely on the surface. Come to find out the carabiner that was back-spliced into the line (bought it like that at WalMart) had un-clipped itself somehow from the anchor. It happened on two different trips (2 different anchor lines from WalMart). There are now two 12lb mushroom anchors (almost in the same location) near Moors Resort & Marina. I do not buy those pre-made anchor lines with the carabiner from Wally World any longer.
I have seen them made using a chain anchor (pictured below) with a winch and anchor rode (rope) that allows the operator to lower the chains so that they will drag on the river bottom slowing the boat. If you want the boat to stop, you drop the chains between the rocks or structure and it catches.
This worked well while smallmouth fishing allowing the angler to make multiple presentations to an area as the boat slowly drifted past.
