coachlaw
I've been running my own boats since I was 7 years old. I've been a scavenger since I was a kid and all my boats were boats that were found and in various states of disrepair. I'm used to leaky aluminum boats. When you find a boat in the marsh after a hurricane and can't track down the owner, you take what you can get. A few years ago, after moving from Louisiana to Texas, I purchased my first "real boat", meaning that it was a boat that had its own trailer. It's a 1984 Lowe 18 foot center console XXwide. I call her the "Ugly Mudda". Anyway, she didn't leak when I got her, but now she does, like a collander. I patched a few holes with JB weld (Not the best option, but I'm a teacher and therefore poor), and I finally consulted a professional. His advice was anything but uplifting. - Sell it and get a newer boat. A few of the holes appeared to be pin holes, but when I pushed on them with my finger, the aluminum fell apart. To boot, the motor blew without warning, but I luckily picked up a 1974 Alumacraft 1872 to keep me on the water the last 6 months while I saved up for a new motor. It has the same problem by the way, but at least the motor runs. (It's an even worse basket case acording to the aluminum guy.)
So I'm going to keep on keeping on until I can save up for another boat. But the question begs itself, How can I make sure this won't happen to the next boat? I'm in salt water only. My boat spends at least 2 days a week in the water as I have a fishing camp that you have to use a boat to get to. I know that bunk board carpet causes electrolysis. I've heard about putting a sacrificial anode (or is it cathode?) on the hull to stop this, but I have had many conflicting pieces of advice regarding the type of metal to use, and if I should connect it to the negative post of my battery. Also if it should be above or below the water line?
It thought this would be the best place to come and ask all these questions. Y'all help a guy out woudja? - Sandy
