Torch and aluminum rods
rusmir
spokane,wa
Does this relly work or is it weak . I researched a bit it seems it can hold up good ?!?!?!?!?
It works, but it's not as easy as they make it seam on the You Tube videos. I bought some Alumaweld rods from Harbor Freight and used them on a few different areas of my boat. Using them on the hull wasn't a big deal but I have some panels that coverer different areas that are thinner and the heat made them warp a bit.
well i finally found a guy that will do it he works here where i work .. so well cee till monday .. if he wont do it i might try it my self but im sure he will tho..
I tried them with no luck,not very strong and didn't hold up.Save your cash and pay someone to tig it for you.For what i spent on roods it wasn't much more to have it tig,and it is strong.The key is do all prep. work and then all they have to do is wield it for you.
caveman
