Troutman3000
I got a few questions too. These are related to my boat however.
1. What are all the bolt on the outside transom? Are they all required on the new one?
2. How do I seal the holes where said bolts are?
3. Do you really need the outside transom if the inside one is replaced?
4. How is the inside transom held in place? By the screws from the outside transom?
5. Is it necessary to seal both transoms with silicone or steel flex?
6. How should I re-attach both transoms?
Thanks for everyones help in advance.
