mychelle1983
- Joined
- Feb 8, 2010
- Messages
- 2
- Reaction score
- 0
have several rivet and small bolt holes in alum. boat.suggestions on products to use to fill holes and that can be sanded & painted-thanks
mychelle1983 said:have several rivet and small bolt holes in alum. boat.suggestions on products to use to fill holes and that can be sanded & painted-thanks
russ010 said:i would put rivets back in them too...
but, they make a stick type of epoxy that you cut off, roll up in your fingers and form in and around the hole. Once it has cured, you can sand it down and paint it
https://www.westmarine.com/webapp/w...8?&cid=chanintel&ci_src=14110944&ci_sku=81628
