wasilvers
I'm thinking of using 1/2 plywood for decking to save weight and money. Maybe you can answer some questions for me.
Thanks for the help!
Today, I found supplies for just about everything I need to get going. I started on pulling the old stuff out now - looks like 3/4 plywood. My boat is heavy, and I'd like to take the family on it and still get on plan with the 17 pitch prop.
Thanks,
Will
- If you used this - What spacing did you use for supports for 1/2 ply? (thinking 12 inches now)
- If you used this - how does it hold up over time? - Is 3/4 going to last longer?
- If you used this - would you use it again or go with 3/4 plywood next time?
Thanks,
Will
