Froggy
I found these instructions on a previous post, is that a viable option.I like to do a simple cleanup, repaint on an otherwise fairly good tinboat, I dont want to get into steelflex etc, just sand, prep,paint etc. is there a simplified version of painting. Thanks
Steps to Painting an aluminum boat:
1. Clean the boat thoroughly with just a simple wash. Wipe the boat down with either mineral spirits or Pettit 120 Thinner.
2. Rough sand the boat with 120 Grit paper just to scuff the boat a little so that the paint will adhere better.
3. Wipe again with mineral spirits or 120 thinner to get all dust off of the boat
4. Make sure to wear a mask while sanding - ALUMINUM is very dangerous to breathe.
5. If there is any bare aluminum showing is the Pettit 6455-044 primer for the bare spots only. The actual paint will stick to the old paint no problem. This comes in a quart and plastic bottle combo pack.
6. WAIT at least 2-4 hours
7. Use the Pettit Coat EZ POXY paint which comes in about 12 colors to paint the boat. The rep said it would be no problem to roll it on, but have someone come behind you with a china bristle bush and going with the length of the boat, use long finishing strokes as it will make the boat look awesome.
8. For a 14' boat he told me I would need two quarts. Use the site as a bearing for your project and call them for specifics.
9. Let that completely dry and then come back with a light 240 grit sand job to get out all of the imperfections.
10. Make sure to get all of the dust off and repaint and let set for 3-4 days.
