C Cass Member Joined Feb 12, 2010 Messages 10 Reaction score 0 Feb 26, 2010 #1 can i use 3/4 osb for my transom if i treat it
Jim Well-known member TinBoats Supporter Joined Nov 29, 2006 Messages 18,305 Reaction score 23 Location Shrewsbury, MA Feb 26, 2010 #2 Cass said: can i use 3/4 osb for my transom if i treat it Click to expand... sure you can, but it will take in water eventually.
Nevillizer Well-known member Joined Jun 23, 2009 Messages 651 Reaction score 0 Location Waco, TX Feb 26, 2010 #3 You can, probably shouldn't though.
C Cass Member Joined Feb 12, 2010 Messages 10 Reaction score 0 Feb 26, 2010 #4 what if i seal it with that fiberglass stuff
Jim Well-known member TinBoats Supporter Joined Nov 29, 2006 Messages 18,305 Reaction score 23 Location Shrewsbury, MA Feb 26, 2010 #5 Cass said: what if i seal it with that fiberglass stuff Click to expand... How big is your boat. You want to try to keep weight to a minimum. Speed and safety reasons.
Nevillizer Well-known member Joined Jun 23, 2009 Messages 651 Reaction score 0 Location Waco, TX Feb 26, 2010 #7 If you actually wrapped the ends with fiberglass and not just the resin it might last. I would just use plywood and treat it.
C Cass Member Joined Feb 12, 2010 Messages 10 Reaction score 0 Feb 26, 2010 #8 thanks guys plywood it is i will just use the 3/4 osb for the decking if thats ok and thank again guys =D> =D> =D>
bAcKpAiN Well-known member Joined Jan 1, 2008 Messages 982 Reaction score 0 Location Phila, PA Feb 26, 2010 #9 If you seal it with glass resin it should last you some, but like thers have said OSB is basicly a saw dust version of a sponge. It will soak up water and rot.
nbaffaro Well-known member Joined Sep 10, 2008 Messages 88 Reaction score 0 Location Lumberton, NC Feb 26, 2010 #10 NO. OSB is not intended for that type of use. It's not strong enough even when it hasn't rotted. Don't do it.
