Froggy
I am doing a new thread on this , I know some of you guys are using this paint or planning to use it. I will add future threads to my Mod down below.
Any how, first off, after sanding lightly ( my boat did not peel) I applied a self etching primer, before that I cleaned the Hull with some Autopart cleaner, let dry, primed. Used a tack cloth today to get all the dust particles off. I then used my Wagner Control HVLP sprayer. I had done some searches and found that some people could not use this tool, some did, some hated it. OK, the product data sheet from the paint clearly indicates it can be applied with a HVLP sprayer. I followed directions, there is a small cup with a hole included in the sprayer kit, you count how many seconds it takes to run out, 25 -40 seconds and you are good to go, very little thinner needed. the paint went on like a charm :mrgreen: applied a thin coat, will lightly send tomorrow and do the next coat. I never used a brush it worked great, here are some pictures some paint is still wet, I just checked the boat is now dead flat. I used 1/2 quart can so far.
