rangerbull
I am a new member and have a 12 foot sears aluminum. I put a couple seats in and made a bracket to move the front seat forward a bit to give more room between fishermen.I moved the oar locks back so you could oar forward from the back seat. The reason is I like floating the rivers here around central Indiana for smallmouth. I would like to here a few ideals on a way to install a drain plug. sort of a pain to tilt it over. I don't want to add a lot of extras cause I like going out alone now and then and want to be able to handle it myself. the way it is now I can slide it in and out of the truck fairly easy. look forward to reading this forum. good fishing.
