Hi. Great website!!!!
I own a 12 foot flat bottom Jon boat, that I bought for $125, with a small trolling motor, and I would like to customize it a bit. The bottom is 36 inches across. It has 2 benches. The ribs go across the bottom, but DO NOT angle up the sides. I don't know the brand. The only manufacturer's mark on the boat is a sticker that says "Big Jon." This boat may have been built as far back as the 60's. Just not sure.
The bottom is fairly dinged up, and most of the rivets leak
My thought is to remove the rear bench and replace with a swivel seat, deck the floor, and add a deck up at the bow (maybe 2 - 3 feet in length) with a swivel chair. Overall, I don't want to add too much weight up high. Most of the added wood will be on the floor of the boat.
I plan on keeping the middle bench, as this boat will be rowed, at least at first. A seat could be added to the bench later on, if/when a motor is purchased. I can't see a seat holding up too well when your body is going through the rowing action.
My questions primarily revolve around the leaky rivets, and removing the rear bench.
Can the rivets be repaired (hammering with a metal brace on the other side)? Or should they just be replaced? If so, what is used. Not pop rivets, right? So what will they be called when I go shopping?
Will removing the rear bench be a problem structurally? If not, then do I drill out the rivets, remove the bench, and plug the holes with new rivets? I have access to low cost welding help. Can the holes be plugged that way, or is that too potentially damaging the the boat's strength?
As far as attaching the deck, I guess angle aluminum will be added to the ribs with screws, and the wood deck is attached to the aluminum with screws, then carpet glued on that to hide the screws. Is that the general process?
OK, many more questions come to mind, but I'll not overdo it on my first post.
Thanks in advance!!!
