neveraseven
I just put Rustoleum Pro Primer for aluminumon my stripped aluminum hull. Is it the same as the self etching primer everyone talks about? I was also interested any input on using the Rustoleum oil based gloss paint for the hull which would be below the water line. I would use a paint brush to put it on. Also, has anyone used this product or should I use something else like an epoxy or polyurethane? Thanks in advance
