DaveInGA
I'm looking at replacing an original 3/4" plywood floor in my boat with .125" aluminum sheet. The original supports were spaced out at 12" for the plywood. What I'm wondering is if I will need to add additional supports to support the aluminum or are the original supports adequate? The supports in there now run port to starboard and the total area to be covered is 52" wide and 59" long.
Thank you,
Dave
Thank you,
Dave
