rebuck rivet or just 5600 coating
williamk12
I have a 1983 sportcraft 18ss that i just purchased this summer. I've been taking on a little water while fishing. aftrer closer inspection i found three screws on the bottom v. apparently the last owner had lost a few rivets. can you replace the rivets without removing the floor ? I would assume removing the floor would be a major pain in a$$ to replace 3 rivets.
any suggestions ??
thanx
Depending on the size, use closed end pop rivets. Only need outside access, and they don't have the mandrel hole. A little 5200 around them and all is well.
