DaveInGA
I'm going to have to run wire while I've got the rear decks out (good opportunity) and it's easy to drill holes, run conduit, etc.
So I gotta fairly quickly pick a gauge of wire for a trolling motor and order it in while I'm doing the trailer. Trolling motor is likely going to be a bow mount Minn Kota Maxxum 55 with 42 inch shaft and variable speed. Boat length is 17 foot front transom to bow. Boat will have MK trolling motor socket (mounted on bracket) and locking plug. Most likely a 50Amp fuse in line.
Please select a gauge wire and if you're not satisfied with the available choices, select larger or smaller and please say what gauge you would use and why in a post.
Also welcome any suggestions on conduit and other wire protection stuff available cheaply/inexpensively at Lowe's, HD or Walmart, etc.
I would do this myself, but I've got a sinus infection with a secondary infected tooth and I'm too zonked on pain killer right now to think for myself. Can't even sleep, hurts too much. If you fellas can help me out, I would greatly appreciate it. I suspect this infection issue problem isn't going away anywhere near as quick as I would like it to.
Thank you,
Dave
Thank you,
Dave
