CoolHand
Has anyone here had any experience with composite materials for decking or flooring? I've been looking for some time for the right material to use for my floor. I wanted to go aluminum to keep the weight down vs plywood. The prices of aluminum are pretty crazy right now though. I was looking to go 1/8" thickness. So I started searching and I found another site where someone mentioned using a material called Alucobond for his boat floor. It is basically two thin pieces of aluminum sandwiching a polyethylene core. I can't find anyone that sells Alucobond but I did find a local supplier of Cbond which seems to be a similar material. Here is some online info on it that I found https://www.cgategroup.com/cbond.html in case anyone is interested.
My question is if anyone has used it and how rigid it is compared to all aluminum? I was looking at 3mm sheets. That puts it just a hair under 1/8" and it's just slightly heavier than all aluminum as well. If it is rigid enough though there would be huge savings. It's $69 for a 4x8 sheet.
So anyone have any info?
