Question, I have done this also ... moved my main battery from back of the boat up front and added a TM battery up front also (for when I get a TM next season). I was in a pinch when I had to move the battery during a camping trip so I bought some cheap cables from a hardware store. After initially hooking everything up it worked fine but after about the 2nd outing the electric start would barely turn the motor over. I thought the battery had gone dead by the sounds of it so I took it off and hooked it up to the charger and it was full charge in less than an hour so I didn't think that was the case. I re-checked all the connections which looked solid to me and put the battery back in but had the same thing, the engine would turn over like normal sometimes but most of the time it was slow as if the battery was dead. Fortunately I also have a rope start on the motor so I just reached back and gave that a pull and was on my way.
Now I'm back home and had this same issue on the water last weekend and want to investigate it. Do you guys think its loss of voltage due to crappy cables? Does the length of cable reduce the voltage? I don't have the box anymore for the cables so I don't know the specs but both pos and neg cables are maybe an 1/8th inch bigger in diameter than a standard pencil and have lots of small copper wires.
Secondary question, if I leave the 2 batteries up front, TM battery and 2nd for running everything else but starting the boat, could I get away with a smaller size battery in the back just to start the boat?
Thanks
