redneck Ingenuity
shinerman77
Williamsburg, VA
Bassaddict and me found a nice lake to fish. the only problem was we wanted to get our boat too it. It is about 100 yards from the parking lot to the water. We have a 12' 1963 sears jon boat. It is too heavy to carry with the trolling motor, battery and all the other fishing gear. I looked for a little cart or something in all the fishing magizines but everything was 50 dollars or more. So finally I came up with this. I spent 11 dollars for the 2 X 4 and all the hardware and just borrowed the rear wheels off my lawnmower.
exacly we are going to try it out tommorrow morning. Hopefully we will come back with some nice fish. It is the same pond I won the labor day tourney out of.
Here is a little tip for ya.
You may want to put a little stop so that the boat doesn't slide back, and try to hit the wheels, while pushing it. A scrap of 2 x material, and a screw will work just dandy.
Awesome job - you can alse use bicycle wheels for the same effect.
We might need a new section - "other boat things we build" or something
Ditto.
Kinda goes under the same lines as that thing I mentioned a month or so back, about just a "projects" section, instead of, or in addition to the jon conversion section.
Call it "The fiddlefart room". I tell my boss that if someone would pay me to tinker and fiddlefart around, I would have it made. Its not redneck inginuity, its just good sense. Why buy something that I can build, and probally better.
Great addition to the boat.
bassboy1 said:
Ditto.
we are working on a projects page as well as the homepage again....couple of months (the web designer has a couple projects ahead of mine)
Just a suggestion, but if you centered the load it would be easier to move around. Push it, pull it kind of like a boat trailer.
bassboy1 said:
Ditto.
I kind of like the "redneck inginuity" name :twisted:
Well?? Did the cart/dolly work out OK?
Did you catch any fish?
And, with Spring/Summer almost here...how are you going to mow the lawn with a wheel less lawn mower? :lol:
