FishyItch
So I have a 14' tin semi-V that I will be working on in the spring. Right now there is a bench that runs across the middle of the boat. It's attached to the sides of the boat to add structural integrity. Originally I intended on keeping the middle in the boat and just putting storage in it instead of the flotation foam that is currently living there.
But is the bench really adding that much stability? Wouldn't I be alright if I took it out? It's a smaller boat and I don't think I'll be going that fast. Also, I'll be adding a deck about 2 inches off of the current floor. That will add some stability, right? Here's what I'm thinking.
Pros for removing the bench...
-more room in the boat
-can move from bow to stern without stepping over the bench (I like this one a lot)
Cons for removing the bench...
-Less support for shape of the boat.
-Less storage space.
-No bench in the center if I need to row the boat. (I've never been totally at the mercy of my motor. I like having oars.)
So this is what I'm thinking. I'll take out the center 50% of the bench. The 25% on either side can still be smaller storage compartment. These "boxes" can also be a good place to mount some rod holders. These "boxes" will also give the sides of the boat something to be bolted to for stability. The middle 50% of the bench I will turn into a flap that will open and close sort of like the ones you see at bars that separate the back of the bar from the front but still act as a bar. This flap would have supports available under it so that the flap could support my weight if I needed to sit on it and row. The supports would be attached to the boxes.
This idea doesn't completely fix the problem of total space in the boat, that is, not much space is gained, but I won't be break dancing or anything in my boat. (Who was it that had a "break-dancing area" in his boat build? I thought that was awesome.)
In the image below you're looking through the starboard side of the boat. The stern is off the screen to the left and the bow is to the right. The lighter grey are the hinges and the yellow are the supports (probably 2x4's) attached to the remained storage "boxes."
Thoughts? Suggestions? Anything?
