jojo
- Joined
- Mar 18, 2010
- Messages
- 231
- Reaction score
- LOCATION
- Wisconsin
I have a 16' Crestliner Mod V Jon Boat. I am looking to add a bow mount TM, light, seat on a stick, and a TM plug receptacle all on the front deck. The problem I have is that the deck is closed off with no way to get under it to fasten bolts.
I know you can get toggle bolts, but I was thinking I could just cut out a hole in the side like the pic below. Do you guys think this is a good idea? I figured it might make it a lot easier than using togglers for everything.
Would the foam underneath the deck get in the way? How much foam is usually in there?
Where would I get the black striping around the edges like in the pic below?
Its not my pic, Im just using it as an example.
