So on a 1232...cutting center seat out is safe?
Roosterrusek
Could not find anything in search but to make more room on my 1232 I was going to cut the center cross seat out. I am betting that's OK right?
You will probably be removing flotation material if you do that, and the bench might be there for structural support too.
I would say it depends on the supports on your floor.If you have good supports on your floor you could brace your sides to the floor.Hope I explained myself so you understand.
