Last week I acquired a 16' Aluminum V-Hull and in it there are two welded boxes that sit above the wooden floor in the open part of the boat. They are welded on the sides and one of them is bolted through the box to the floor on the inside, this box is used for storage. The other one, on the port side, is welded to the side and is bolted to the floor with brackets on the sides of it. I do not know how to get the floor out from under it if the floor rots, looks like you have to grind the welds. Seems like the floor will rot with this livewell on it.
Well anyway, both boxes stick out only about 18 or 20 inches into the open space, and are about 12 inches tall and 12 inches wide. In this livewell and I use that term loosely, there is a outlet in the box, almost level with the bottom, that passes through the floor and has a hose attached that runs completely under the floor to the transom and the end of the hose is open near the bilge pump and has no valve or plug. So any water that you put in the box runs out immediately. Right near the end of this hose is a through hull, below water level outlet that has a 4" piece of hose attached that has been plugged made of another material. The boat drain is right next to this hole.
The bilge pump which is right next to the boat drain hole has a hose that empties out just below the rail on the starboard side of the boat very close to the transom. I would like to make this a functional livewell. Does anyone know what the configuration should be or how to make this an operational livewell?
Grandpa Chase
Grandpa Chase
Grandpa Chase
Grandpa Chase
