I just purchased a new Xpress 1650VJ with a new 30hp Tohatsu EFI fourstroke with electric start, power tilt/trim for $6000. The boat is 340lbs and motor is 185lbs. What kind of performance should I expect from this combo?
my 15 foot ouachita weighs more than 400 pounds and loaded with all my fishing gear itll run 22mph according to the gps and thats just with a 15hp mercury
I will get some soon. I just mounted my new motor and the anti-ventilization plate is right at 1" below the transom. Is this worth messing with to get level? Also how much difference will I notice from going from a 9.8x11 prop to a 10x13?
as was explained to me, more pitch more speed/less power. im guessing you will not get any good from the 13, i would try what you have first. see were the rpms lie at wot.
