Need some help putting carpet down on my jon boat
ILOVTOFISH
Post by ILOVTOFISH »
I have a 14ft jon boat and i have already used the 3m77 and 90 and it seemed like it was gonna hold well.Once it got wet that was it as the carpet just peeled up like an orange.Is there any other glue people have used here that is waterproof?The only other thing i can think of is liquid nails but i want to be able to replace it when it wears out.I know with the liquid nails it's almost if not permanent.
If anyone has used a good glue please let me know as i need some help on this problem.The second thing i was thinking was a piece of plywood on the deck and the back and then just glue the carpet and throw a few screws in it also to it but i don't want my boat to be to heavy.I only have a new 9.9 2stroke yamaha on it.Thanks for any help.
possom813
Post by possom813 »
sub'd for the info
No worries bud, the flood will put out the fire.
rusty.hook
Post by rusty.hook »
On my boat I have now there was already brown carpet in the floor so I just cut a piece of plywood the same size and glued my grey carpet to it with "outdoor carpet glue" and just laid it on on top. The glue is what they use on patios.
My boat stays under my "boat port" aka "car port" I built next to my house, so its out of the weather all the time except when i go fishing, which I am getting ready to do now when I finish this reply, jus' sayin'
A BAD DAY ON THE WATER IS BETTER THAN A GOOD DAY AT THE OFFICE ANY DAY OF THE WEEK. MY FAVORITE TWO DAYS THAT START WITH A "T", ARE, "TODAY & TOMORROW".
russ010
Post by russ010 »
I used 3m90 for the hydromat on my boat.. granted, it's not carpet, but it hasn't peeled up at all and my boat sits out in the weather uncovered...
the "best" stuff that I've seen used for carpet is Henry carpet adhesive... You can get this stuff at Lowe's. Bassboy1 I think uses this on all of his builds - https://www.wwhenry.com/content.aspx?id= ... =79&pID=89
ohiobass
Post by ohiobass »
russ010 wrote: the "best" stuff that I've seen used for carpet is Henry carpet adhesive... You can get this stuff at Lowe's. Bassboy1 I think uses this on all of his builds - https://www.wwhenry.com/content.aspx?id= ... =79&pID=89
=D> =D> =D> AGREE 100%!
This is the best I've ever used! =D>
ILOVTOFISH
I have heard of that stuff before but i also heard it takes days to dry.Is this true or does it dry rather quick.Is it waterproof to?I was under the inpression the 3m was one of the best but i have used it twice and it has not held up.Maybe i need to put a ton of it on.I just used enough to cover the aluminum and the back of the carpet and it seemed like it was on there like a rock.As soon as a little rain hit it that was it as it just peeled up.I will have to check out that henrys carpet glue today i guess.
Thanks guys for the tips.
ckr74
Post by ckr74 »
The Henry adhesive works well. I got mine from Lowes. Just make sure it's outdoor carpet adhesive. It does take a while to dry so you probably wouldn't want it to get soaking wet for at least a week. Read the directions.
ohiobass
Post by ohiobass »
Just got done making a drop in raised rear deck on my Grumman 1467SP, and used the Henrys Outdoor carpet stuff.
It's take about a day to dry & get rid of that "tacky" feel, and can says to stay out of direct water/rain for 5 days.
cavman138
Post by cavman138 »
I just used the outdoor carpet glue that Lowe's sells. I'm pretty sure it was Henry's as well and has worked fine.
My work in progress:
My PolarKraft 1648 Mod!
WaHooWa
The definition of insanity is doing the same thing over and over and expecting different results.
BOB350RX
Post by BOB350RX »
THIS STUFF WORKS
THIS THING USED TO FLOAT
https://www.tinboats.net/forum/viewtopic ... 21&t=20263, my 82 mirro build
https://www.powerstream.com/wire_size.htm voltage drop, and wire size charts, pretty useful stuff!! not just for 12v either
ILOVTOFISH
Henry it is.Does it come up easy when you want to replace the old carpet?
BOB350RX
Post by BOB350RX »
never had to remove it so i dont know realy
dr_beerman
Post by dr_beerman »
just picked up 2 gallons of Henry outdoor glue at Lowes on sale $9 each
Driftingrz
Post by Driftingrz »
would staples not do the job? everything ive built that had wood and carpet has lasted just fine and looks great with stretched tight carpet and staples.. has nobody else gone this route? i never thought it would be an issue, maybe im wrong and glue is the way to go.. i havent done a boat yet
BOB350RX
Post by BOB350RX »
Driftingrz wrote:would staples not do the job? everything ive built that had wood and carpet has lasted just fine and looks great with stretched tight carpet and staples.. has nobody else gone this route? i never thought it would be an issue, maybe im wrong and glue is the way to go.. i havent done a boat yet
I USE A COMBO OF GLUE AND STAPLES, THE STAPLES HOLS IT TILL THE GLUE DRIES, NEVER HAD ANY PROBLEMS
