flintcreek
Finally got my latest project out on the water today it is a 16'x48' LoweLine Hustler. I had several issues to work out, but the one right now I am trying to figure out how I want to fix it is the it was leaking at the drain plug and I had it as tight as I could get it. When I got it back on the trailer and checked the drain hole, it was very rough had big ridges that the drain plug was not sealing. I am thinking about using JB Weld to try to fill the ridges and then see if I can sand it out nice and round again, has anyone ever had this type of issue and how did you fix it.
Thanks,
Flintcreek...
Thanks,
Flintcreek...
