Ouachita
I got a deal on two new bilge pumps on the wal-mart clearance rack. $2.50 for a 500gph pump. I am planning on mounting one in both back corners. My question is if you can run two pumps to the same discharge port? I want to run them to a T fitting then to the outlet. I have never had a mounted bilge pump so this in new to me. Usually just get on plane and pull the plug
