plywood
berger
so i have been reading and i see that some say the only difference between marine grade and the oak plywood or the nxt best thing is the voids between the layers. if this is true then after u cut it and u find a hole cant u just silicon it and then water thompson seal the whole board cuz the price difference is like twenty or more a sheet. just needing some suggestions or more info if anyone has used regular oak plywood
yea i read about pressure treated and i asked the guy at home depot about exterior use plywood which one is that exactly he didnt seem to sure
Remember too that high grade plywood has more plies and are therefore more stable. It's not just about voids although that matters too. More expensive plywood will have better glues, better quality wood and more plies. Some cheaper plywood will have only 3 plies for a 1/2" sheet. Marine plywood will have more plies - probably 5 for the same sheet. This tends to be true for cabinet grade plywood as well. Cheaper plywood requires more structure to keep it from warping or changing shape. Think about longevity also and the conditions in which the plywood will have to perform. I don't generally fish in rainy/stormy weather and keep my boat covered so my plywood doesn't get soaked. I assume it will last longer than if I was in the rain a lot. Here is a description of marine plywood from Wikipedia...
Marine plywood is specially treated to resist rotting in a high-moisture environment. Its construction is such that it can be used in environments where it is exposed to moisture for long periods. Each wood veneer will have negligible core gap, limiting the chance of trapping water in the plywood and hence providing a solid and stable glue bond. It uses an exterior Water Boiled Proof (WBP) glue similar to most exterior plywoods. Marine plywood is frequently used in the construction of docks and boats. It is much more expensive than standard plywood: the cost for a typical 4-foot by 8-foot 1/2-inch thick board is roughly $75 to $100 US or around $2.5 per square foot, which is about three times as expensive as standard plywood. Marine plywood can be graded as being compliant with BS 1088, which is a British Standard for marine plywood. There are few international standards for grading marine plywood and most of the standards are voluntary. Some marine plywood has a Lloyd's of London stamp that certifies it to be BS 1088 compliant. Some plywood is also labeled based on the wood used to manufacture it. Examples of this are Okoume or Meranti
The post by bobberboy is right on...but...
For most applications in recreational boats high quality exterior grade ply is all you need. There may be some voids but if they happen to show up on one of your cut lines a quick fill with thickened epoxy will cure the problem. I would advocate steering away from the big box stores and their crappy Chinese plywood and head straight for your local lumber yard. You will know you are in the right place if the folks you talk to actually know about wood and can help you make the right decision after you tell them what you are trying to do.
Additionally: Thompsons probably works just fine but if you really want it to last and stay dry, coat your plywood with boat building epoxy. You simply can't beat the waterproofing it provides. The stuff I use comes from Raka ( www.raka.com ) give them a call and tell Larry what you want to do and he will set you up with the right product.
