seat clamps on benches with lips?
sirbeigealot
Do those adjustable seat clamps work on benches that have a lip?
My benches have about a one inch lip on either side.
I was thinking that I could possibly set a few 2x4's or even 3/4 plywood against the bench so that the clamps would have a solid surface to affix to.
yep, mine are clamped to the lip.
edit: I added a 2x4 and an extra block of wood to hold them down.
I NEVER HAD ANY LUCK WITH THEM WITHOUT PUTTING SOMETHING TO MAKE UP THE DIFFERENCE BUT MAYBE I DID SOMETHING WRONG
My boat has those lips. What I did was to place pieces of wood under the lip front and back then a second piece of wood on top of the first even with the top of the bench. Then I put a piece of wood over the bench connecting the the front and rear pieces. I added one more piece of wood on top of it, this is where I mounted the swivel. The whole thing will slide side to side on the bench.
I will get some pictures when it stops raining.
Removable seats work better in a small boat. You can move or remove them to suit your needs.
But if you want to permanently install one or more these work good.
Walmart also sells these.
https://www.cabelas.com/product/Boating/Boat-Seats/Pedestals-Bases|/pc/104794380/c/104705280/sc/104492880/Swivl-Eze-3434-Pin-Pedestal-Bases/700980.uts?destination=%2Fcatalog%2Fbrowse%2Fboating-boat-seats-pedestals-bases%2F_%2FN-1100617%2FNs-CATEGORY_SEQ_104492880%3FWTz_l%3DSBC%253Bcat104794380%253Bcat104705280&WTz_l=SBC%3Bcat104794380%3Bcat104705280%3Bcat104492880
If you want the seat up higher
https://www.cabelas.com/product/Boating/Boat-Seats/Pedestals-Bases|/pc/104794380/c/104705280/sc/104492880/Springfield-Explorer-Pedestal/699624.uts?destination=%2Fcatalog%2Fbrowse%2Fboating-boat-seats-pedestals-bases%2F_%2FN-1100617%2FNs-CATEGORY_SEQ_104492880%3FWTz_l%3DSBC%253Bcat104794380%253Bcat104705280&WTz_l=SBC%3Bcat104794380%3Bcat104705280%3Bcat104492880
I just picked up two of these seats:
https://www.basspro.com/Bass-Pro-Shops-Tournament-Pro-Hi-Back-Boat-Seats/product/10205157/-1646358?cmCat=CROSSSELL_THUMBNAIL
I also picked up two of the clamp on swivels.
