nashua fisherman
on an unknown quest for speed. boat hit 18mph with me and the wife and 21mph by myself without the jackplate. trying to get below 9% prop slip. motor is an 85' 8hp johnson. boat is a 65' 12' sea nymph. i just need to seal the wood, fill some hole and add the brace across the top of the inside of the transome before a trial run. ill probably trim some of the aluminum too after the final height is set. just figured ide share.---tom
