towing a boat question
diabetik11
Post by diabetik11 »
i have a 2001 2.5 liter 4 cylinder ford ranger and i am wondering if this has enough power to pull a mirrocraft deep fisherman II, trailer and 15hp motor, trolling motor and battery the boat has the open floor plan(split middle seat and floor). can my truck do it or should i look for another boat
basstender10.6
Post by basstender10.6 »
First off you should check your truck owners manual and see what the maximum tow load is, then find out how much the boat weights. It should be able to do it considering it is a light boat.
2000 Procraft 190 SuperPro
2000 Mercury 175 EFI
S10ssguy
Post by S10ssguy »
I'd vote yes
Ictalurus
Post by Ictalurus »
S10ssguy wrote:I'd vote yes
X2
flatboat
Post by flatboat »
i would think so
Loggerhead Mike
Post by Loggerhead Mike »
I don't think that rig will weigh enough to cause any problems esp of you won't be pulling many mountains
crkdltr
Post by crkdltr »
Should be fine but avoid steep ramps. I used to own a 1992 Ford Ranger with the weaker 2.3 4 cylinder (lima engine). About 90 hp. It was able to tow and launch a 15' bass boat. It struggled but was never not able to retrieve the boat from out of the water. The main thing is making sure you have traction. You need weight over the rear axle and keep your rear tires from getting wet.
reedjj
Post by reedjj »
You should be fine. Like stated earlier traction is the big problem, especially on steep ramps. You might have a semi hooked to a jon boat but if that ramp is wet and has algae on it your not going anywhere. If its a normal boat ramp that people use on a regular basis I wouldn't think twice about launching or towing a full on fiberglass boat with that truck.
Where I live I see some pretty amazing things at the boat ramp........
bulldog
Post by bulldog »
My buddy had the same truck in a similar year and I will tell you this, those trucks are tanks and will do things that you would not believe. Mud, rocks, jumping, it will do it all. Besides the fact that it will, just check to see what is the recommended towin rating and you should be fine.
I vote yes and I think it will have absolutely no problems whatsoever.
BassBlaster
Post by BassBlaster »
I have a 99 S-10 with a 4 banger. It towed my old boat just fine. 15' deep v with a 40 horse merc. I dont forsee any problems with the 14 footer I'm currently working on. As stated before, traction on the ramp is the issue. I have never not gotten the boat out of the water but I have spun the tires and got a little skeered several times. Just use a dry ramp if there is one and dont back into the water. Once you get past that water line, you get into some really slippery algae.
Once the water level was so low that I backed the trailer off the end of the ramp. That was fun. I had smoke rolling off those little tires but I got it out!!
DanMC
Post by DanMC »
No problem :!: ...make shure cooling is up to snuff (radiator) and maybe run synthetic engine oil, i'm only saying that because anything will help to reduce heating/stress on the motor's internals.And it would not hurt to flush the transmission oil too...just to be safe.
Dan
Aaron Lariscy
Post by Aaron Lariscy »
I know its off topic but this weekend at the marsh there was a guy pulling a 19 foot bay boat with a 150 johnnyude with a 80's model Nissan 4 banger.
:LOL2: I'm sure our Ranger will do fine with that little tin you have...
crkdltr
Post by crkdltr »
Aaron Lariscy wrote:I know its off topic but this weekend at the marsh there was a guy pulling a 19 foot bay boat with a 150 johnnyude with a 80's model Nissan 4 banger.
Wow, that would have been a sight to see. Surely that boat/trailer weighs more than that truck. :shock:
PATRIOT2
Post by PATRIOT2 »
I would certainly hope it would, since I tow my 14' boat and quads with a 1995 Saturn 1.9 SL2 5-spd.
Aaron Lariscy
Better belive it and it hasn't been that long ago I saw someone towing a 20 something foot pontoon boat with one of those chrysler cross over thingies down the interstate. I have pulled one the same size with a 2011 cummins 2500 and know it had to be one heck of a ride it looked like you could have driven the car between the logs and used the car as the trailer...
