Jdholmes said:
I would think you would waste a lot of potential storage space filling it up with empty bottles to match the buoyancy of a closed cell foam...we are talking keeping 1000lbs + afloat. That is a lot of bottles.
I would rather place sheets of closed cell foam on the bottom and not lose my storage space.
aeviaanah said:
Well 1000lb is about 450kilograms. By this do you mean I will need 450 liter bottles? Can you give me a rough estimate?
no offense, but i think you guys are forgetting to factor in the specific density of water. your 1000lb payload will not weight 1000lbs when you submerge it in water, thus you will need far less boyancy to keep it afloat. the article posted above supports this principle.
in theory, the same volume of foam will have roughly the equivalent amount of boyancy as the same volume of air (in a bottle). test it in a bucket and you will see what i mean.
i'm not trying to convince you because foam and bottles have pros and cons, we are free to choose whichever we are comfortable with. foam is really more efficient, that's why professionals use it. but since i am a diy person, i try to find cheap alternatives. a bunch of bottles will have space between them which will fill up with water, as opposed to foam which will be tightly packed. so effectively, the same compartment filled with foam will be more bouyant than if it had bottles inside. you can shape the foam to fit wherever you want to put it, but you can't do this with bottles. i do not need that much boyancy, so i can get away with this disadvantage. but just like most boaters, i appreciate extra storage space. but foam comes at a cost. because of this, i'm thinking of installing an alternative to my bottles. i intend to place thick plastic bags in smaler compartments, then blow the bag and seal the openings. the result will be an air bladder that conforms to whatever shape the compartment is. i am not yet comfortable with the idea because of the possibility of puncture, but i will do it once i see a suitable "bladder" material.
