Good idea TNtroller. Thanks! Anyone else? Lots of views, no comments...TNtroller said:might consider moving the forward batt to the other side, your pic shows both batts on one side of the boat, their weights are consistent, everthing else is variable (amount of gas, tackle, whatever else you have in the boat) unless you got something heavy to balance it out.
aeviaanah said:Good idea TNtroller. Thanks! Anyone else? Lots of views, no comments...TNtroller said:might consider moving the forward batt to the other side, your pic shows both batts on one side of the boat, their weights are consistent, everthing else is variable (amount of gas, tackle, whatever else you have in the boat) unless you got something heavy to balance it out.
Right on, will do. Yes I will move storage hatches a bit farther back. I will also recess the trolling motor foot pedal. I weigh 160.Sawdust Farmer said:aeviaanah said:Good idea TNtroller. Thanks! Anyone else? Lots of views, no comments...TNtroller said:might consider moving the forward batt to the other side, your pic shows both batts on one side of the boat, their weights are consistent, everthing else is variable (amount of gas, tackle, whatever else you have in the boat) unless you got something heavy to balance it out.
I agree, you might even want to move it back further. Depending on your weight fishing from the very front of the boat.
sf
aeviaanah said:This is my weight distribution proposal...any suggestions before I get to cutting holes in deck? This is a 12' Aluminum boat will be using a new 15HP 4stroke motor. Seats will be on pedestal mounts.
Hanr3 said:I think you need to research how much that 4 stroke motor is going to weigh. Thinking its around 150 pounds or so. That will be your biggest issue. Go with a 2 stroke and cut that weight in half.
15hp mercury 4stroke is 135lbs...i only weigh 160...you think that will be an issue?Hanr3 said:aeviaanah said:This is my weight distribution proposal...any suggestions before I get to cutting holes in deck? This is a 12' Aluminum boat will be using a new 15HP 4stroke motor. Seats will be on pedestal mounts.
On a typical day it will just be me and one other passenger. My ol lady weighs 150 or so....around 300lbs for the both of us.nomowork said:Hanr3 said:I think you need to research how much that 4 stroke motor is going to weigh. Thinking its around 150 pounds or so. That will be your biggest issue. Go with a 2 stroke and cut that weight in half.
I replaced a 20hp Johnson two stroke with a brand new Honda 15hp four stroke. The Honda was considerably heavier! I had to position the motor stand next to the transom and give it all my grunting power to put it on the transom, whereas the old motor I could just carry it around with two arms.
How many passengers and their weights will be important too. Too much weight up front is another consideration when driving in choppy waters. Good luck.
Yes there will be plywood to mount trolling motor. Didnt think of the length gettin in the way. Thanks for the heads up. Good idea on moving seat back as well. Thanks again!FuzzyGrub said:Weight is your enemy in a small boat. Consider one large deep cycle battery for everything, vs two.
I assume there is another piece of plywood on the bow to mount trolling motor. Get a rough idea on how far back that will come based on trolling motor you choose. You may want to move things back, accordingly.
Consider moving your front seat back further, to give more room for standing. I only sit when tired.
You may want to stand on your front bench to do a water stability test, before making all the mods.
Ok will do. You think I should exclude the livewell?Hanr3 said:Put the starting battery up front too. That will help balance the load.
Find out the weight of your batteries.
Typically the three heaviest items (excluding people) is the motor, batteries, and gas tank. Balance those three out the best you can.
aeviaanah said:Ok will do. You think I should exclude the livewell?Hanr3 said:Put the starting battery up front too. That will help balance the load.
Ok I'm sold on the livewell, ill be sure to keep that around. So you are saying go ahead and buy the good/bigger cables eh? Makes a big difference?Sawdust Farmer said:aeviaanah said:Ok will do. You think I should exclude the livewell?Hanr3 said:Put the starting battery up front too. That will help balance the load.
I'd go with just one battery, place it where it balances best. No longer than your boat is the current/voltage loss won't be too bad with decent size cables. If you run it down with the trolling motor you can always pull start.
As for the live well, I think you need one to fish. It doesn't have to be full all the time and doesn't weigh much empty.
sf
Yea good point, I thought moving the fuel tank and battery in the third seat would help balance the weight a bit closer to the bow. I havent decided exactly how I will place those but good point. I could put a layer of foam then plywood and a the stuff on top of that. What you think? Ill be sure to make the livewell lid sturdy enough for a seat. Thanks.FuzzyGrub said:The space between the 3rd bench and transom is generally not used. I'd keep the foam in the bench and locate the fuel and if keeping 2nd battery behind it. Saves always flippin the lid up to see how much fuel is left, too.
Keep in mind with whatever lid you have on the livewell, the passenger will be sitting on it while under way.
That may throw the weight displacement off. Lets see what they have to say.Jdholmes said:Valid point about the live well lid if you have someone sitting there...but what about doing a smaller lid on the live well and offsetting the passenger seat.
Will do...thanks man youve been a great help...Hanr3 said:aeviaanah said:Ok will do. You think I should exclude the livewell?Hanr3 said:Put the starting battery up front too. That will help balance the load.
Include the livewell. I forgot it.
Water weighs roughly 8 pounds per gallon. Assume your livewell will be full of water all the time when you plan your boat layout.
Thanks for the pdf file. I will definitely read before I get a battery.FuzzyGrub said:A deep cycle battery can be used for starting, but starting can't be used for trolling motor. The cranking amps needed for your small outboard, should be minimal. https://instoresnow.walmart.com/upl...JCI_11969_EverstartBP_D_boating_US_ENG_01.pdf
I wouldn't tear into the bench seat and have to find somewhere else to add the foam back for a slight offset in weight distribution.
