urethane vs exterior paint
fishingmich
Post by fishingmich » 03 Oct 2011, 13:44
Is urethane better exterior house paint for sealing untreated wood? What are the pros and cons.
I fish, therefore I am AWESOME!
16' Smokercraft V Hull
15 hp Merc
nosticks
Post by nosticks » 07 Oct 2011, 16:20
I would thing urethane would be better, but why would you not use a two part epoxy, either a marine paint or better yet use epoxy resin.
Lowe Angler A1257
Tohatsu 9.8 4 stroke
Continental Trailer
reedjj
Post by reedjj » 07 Oct 2011, 22:25
Go with the "spar" Urethane. It is better than using thompsons water seal, better than treated wood, just as good and cheaper than Marine Grade plywood, and a lot easier than encapsulating it in fiberglass resin (which is probably the best way, but a pain).
I used the Helmsman brand in a spray can. 3 coats, paying special attention to edges and where any cuts were made. You can then put some sort of non skid on or put carpet over it. I painted mine OD green and it worked great!
