hi all new to the board
larry glady
Dillsburg PA
im thinkin of puting cork floor in the bottom(floor) of my 16ft Sea Nymph bare aluim floor now i want to build it up a 1/2 inch so the water in the boat will flow to the transom right now water lays inbetween each rib there r no limber holes to allow flow to the rear can buy 1/4inch thick cork and laminate any one try before cork is light and will bouyance prob use epoxy , thanx Larry
Hey Larry..... Welcome to TinBoats! Happy to have you here.
I can't really give you any advice on the cork flooring as I'm not familiar with the material. The cork that I'm somewhat familiar with is very soft and could hold/absorb water. THAT...you want to avoid for sure.
Hang tight...I'm sure you'll get more and better answers soon.
Welcome to the forums.
I have not heard of anyone using cork...what kind of cork are you talking about? indoor flooring cork?
i'm thinking cork used as underlay for floors it comes in rolls 1/4 inch thick light weight water resistent epoxied should seal and not absorb???
ahhh....I know what you mean...odd idea.
I would suggest getting a sample first and doing some testing on it.
I don't know how well it would take the epoxy.
If you are planning on covering it....I used the blue 1 inch (I think) foam from the hardware store. I covered my floor in aluminum too....It worked very well.
Do not use this foam near any gas or gas spill areas. The gas will eat it up.
no I dont want to cover the floor& yes the gas will eat the blue foam. maybe i'll just paint it up and forget about it, wish i could post pics maybe glue the cork down and paint with bedliner or something, thanx for lookin
I think pictures would definitely help...I don't think I am the only one confused by what you are trying to accomplish...
exactly melty only need about 1/2 inch rise& ribs r about 8inchs apart even the drain plug in off the floor at the transom about an inch is there a place that tells u how to post pics here somewhere?
https://www.tinboats.net/forum/viewtopic.php?f=1&t=3664
I finally got the pictures up. check them out and see what you think.
Grizzly grip is about as thick as bed liner type paint. Heres a picture of my boat it has two coats of the fine grizzly grip on it.
