What thickness floor should I choose
SNOOKED OUT
Orlando, Florida
I need a hand choosing a floor thickness as this will be my first total remodel and I want it done right. I know I'm gonna go with aluminum. Thanks
JasonLester said:
fool4fish1226 said:
With proper bracing 1/2" is fine - That's what I used on mine and it is super solid
I think he means aliminum not plywood. 1/2 aluminum floor ....that may add some weight :D
Sorry missed the aluminum part - I think 1/2" aluminum would be a little over kill :shock:
Haha.l.nice...1/2 inch.
Nah, if you are putting it in a non elevated position you can actually do as low as 1/16th with no issues. Put foam underneath it and you are good to go. If your are iffy with that just hop up to 1/8th.
i used 1/8 for my low floor still have plywood on the decks.
after feeling it i wouldnt go any smaller. i also used 1.5x1.5x1/8 angle stock for building my decks
