Adding a drain hole?
catman529
Boat I got has no drain hole. If I want to add one, does anyone know where I could get some aluminum pipe to do the job? Also, is there a good way to seal it in place without welding? I was thinking maybe some 5200, JB weld, or something along those lines.
How about using something like this
Here a reference link I sure you could fine it much cheaper
https://www.amazon.com/Seachoice-18781-Screw-Type-Drain/dp/B002IZJ3TY
Mine didn't have one either so I went to bass pro and got one of these
https://seasense.com/products/36/flypage/details/2545
I flattened one side of the flange so it would lay flatter to the floor. I sealed it with marine silicone but plan on changing that to 5200 one of these days. My only complaint is I would rather it be totaly flush with the floor. But I like the thought of it sealing itself if the plug isn't in (one way flow) If I remember right it was $12 at bass pro and I have seen it for the same at Walmart.
That's what I used on my jetboat, and on my 16' Triton. Both boats had internal drain plugs, but it was such a PITA to get to them in the tight confines of the bilge, I went with these external plugs. Now, it's a LOT easier to pull the plugs to drain the boat while it's on the trailer.
