removing rivets
ScratchyBass
removing rivets
Post by ScratchyBass » 22 Feb 2012, 10:36
I just bought an aerocraft aluminum boat and I'm going to do some modifications but im a little unsure of removing the rivets and are there special rivets I have to put back? Any info on the subject will be gladly appreciated
removing rivets
Post by fool4fish1226 » 22 Feb 2012, 10:48
You have a few options available to you. You can use solid rivets which need to be bucked or you can use closed head pop-rivets that work just fine.
Here a youtube video of the closed head rivets
Hope this hepls
Project "A Little Snookered" http://www.tinboats.net/forum/viewtopic ... 21&t=22132
pipemajor
removing rivets
Post by pipemajor » 22 Feb 2012, 13:01
Hey ScratchyBass,
I re-rivetted my entire 1232 using solid rivets. I bought them from Grainger for ~$10.00. I used the 1/4" x 3/8" rivets with the big rounded head. The rivits I removed were 3/16". Since the boat was all open, I bought a cheap air hammer/chisel from Harbor Freight ($8.00) and cut the pointed chisel flat and countersunk it with a 1/2" drill. I drilled the hole for the rivet one size larger than 1/4". I bought some 3M 5200 quick set marine sealent (Home Depot $9.00) and rimmed the hole before inserting the rivet. I backed the rivet with a 2 lb one jack and used the air hammer to mushroom the rivet head.
Work real well...I installed ~60 rivets. I know this might be more than most people would do, but I wanted to make sure the rivets were set well and didn't want to have to remove the deck for any weak rivets in the future. The only Rivet that didn't set well was the first one my wife helped me with #-o
If you buy the closed end rivets, use the 3M 5200 sealent.
Good Luck :!:
Cheers :beer:
ScratchyBass
removing rivets
Post by ScratchyBass » 24 Feb 2012, 13:45
Thank you guys for the help..
