Olympic WaterGuard wood waterproofing
Trinity
Lumberton, NC
Anyone tryed olympic WaterGuard wood waterproofing? I used it on my first tin but didn't keep the boat long so I don't know the long term effects.
https://www.pro.olympic.com/olympicpro/products/exterior-stains/clears/waterguard-wood-clear-waterproofing-sealants.aspx
How much wood are you doing?
With a linseed oil base I don't think trying to stick anything to it like carpet glue would be a good idea.
Epoxy resin and exterior grade spar urethane are better options I think, if you've got a sizeable amount of square footage to do I'd go with the epoxy... if just a little bit use the urethane.
What advantage would that be over just using the Outdoor enamel paint. I am using it on the Spectrum boat in my signature block.
Epoxy resin is an extremely tough penetrating coating. you can't push a sharp wood chisel through it like you can with the others. It's also an adhesive so it bonds your wood together.
Seal your wood with 3 or 4 coats of epoxy resin and you won't have to worry about it for the rest of your life.
