fowlmood77
I often go fishing with my two partners, but since they have four legs each and no arms, they can't help to much with launching. One of the lakes I fish often has a very shallow ramp, so much so my front tires are in the water before the boat will float. Therefore I have had to come up with a way to lanch the boat from inside the truck, and here it is:
I have a rope a little longer than the boat (it helps if it is a loating rope) that I tie to the front of the boat. Then I take the rope under the boat, in between the bunks to the back of the trailer where I tie the other end. Then, I back the boat in until she floats off from the trailer. This is where the "floating" rope will help as it shouldn't get tangled in the bunks. After she has floated off a little, I slowly pull up until the rope is taught then pull her to shore. This is one of the beauties of a "tin" boat, being that alot of them you could pull up onto the concrete. Of course I wouldn't do this with a new G3, but my boat is far from that. :roll:
Tight Lines All
Tight Lines All
