Screwing it Down
Califishin
I have a 86' Fisher that seems to have a few things that are loose. The trolling motor sits on a mounting plate so when you hit the motor to go it will lift on one side and Im sure it scares all the fish as it is really noisy. I can screww it to the deck but what do I use. The mount legs sit on the carpet so I would have to screw through that as well.
Also looking for a new wind shield for the consel.
The part that fowlmood has posted should do the job for you but if you can access the bolts from under the deck I would add a big washer to the bolt to help spread the load a bit
Wayne
