Seat pedestals
DyerBassman
Indiana
I have a Wise adjustable seat pedestal, 7" to 13", and have a problem with the pedestal rocking back and forth slightly. It's obvious that the problem is where the pin goes in the two pieces as it leaves just enough leeway that the pedestal rocks back and forth just enough to be annoying. Has anyone else had this issue, and if so, any ideas to stabilize it? Thanks!
If you have the 3/4 pin base with the nylon insert check to make sure the base fits tight, If not you can try to email them. I sent them an email asking if I could purchase the nylon insert for the seat bases, they mailed me two at no cost. I'm not sure if that's the problem you have or not.
