Cable mess on deck due to Big Foot switch
Andy Taylor
Oconomowoc, WI.
You guys with a Big Foot switch on your front deck, what did you do to manage the cables? I have the 2 cables from the switch, and the trolling motor cables all on the deck now. The battery is on the left front floor, right where the deck ends. Thanks.
Big grommet for 2 6 gauge wires. In my current boat I am mounting a anderson connector to the deck. I will drill a hole that's a bit oversize, then fill it with silicone after the wires go thru., I wont use any grommet as it will make the hole far to big. If the wire is secure on each side of the hole no grommet is needed, the silicone will act as a shield and keep the wire in place.
