Jon boat repair question
beginnerfisherman81
Post by beginnerfisherman81 »
I have a 12 ft sea nymph aluminum jon boat it leaks a little in the rear by where the guy I bought it from put new piece of treated wood for the trolly motor mount. Is there anything I can buy at bass pro or anywhere else that I can put around that area to seal it from leaking. Its not alot of water but enough that it needs to be fixed. Also could I put something around the screws to seal it there too. Thanks for the help.
1983 12' ft Sea Nymph Aluminum Jon Boat
tgmobile1
Post by tgmobile1 »
3M 5200 Marine Sealant, stuff is awesome!
lckstckn2smknbrls
Post by lckstckn2smknbrls »
First remove the treated wood. It's not good on an aluminum boat it will lead to corrosion and pitting of the aluminum.
Vermonster
Post by Vermonster »
lckstckn2smknbrls wrote:First remove the treated wood. It's not good on an aluminum boat it will lead to corrosion and pitting of the aluminum.
+1 and you likely want to clean it with a wire wheel too. Anything you add the 5200 too should be as clean as possible so it seals up nice.
Vermonster
Click to see my build: 1972 Richline 14' Sportsman V-hull
beginnerfisherman81
If I take off the treated wood what do i replace it with to mount my trolly motor on to. Sorry for all the questions but its my first boat and I want to make sure its safe for me and my son to go out on when its time. Thanks again everyone.
Coach d
Post by Coach d »
Get a piece of plywood and seal it with spar urethane.
The only place success comes before work is in the dictionary. Vince Lombardi
lckstckn2smknbrls
Coach d wrote:Get a piece of plywood and seal it with spar urethane.
Exterior grade plywood.
MrSimon
Post by MrSimon »
Wouldn't a trolling motor mount be above the water line? What exactly is leaking?
Pics and videos of my past fishing trips: https://www.tinboattravels.com
jigngrub
Post by jigngrub »
beginnerfisherman81 wrote:If I take off the treated wood what do i replace it with to mount my trolly motor on to. Sorry for all the questions but its my first boat and I want to make sure its safe for me and my son to go out on when its time. Thanks again everyone.
If the treated board is 1 1/2" thick use 2 pieces of 3/4" plywood (exterior grade) glued and screwed together with stainless steel screws.
Seal the piece of plywood with exterior grade Spar urethane, 4 or 5 coats.
Install the piece back using stainless steel bolts or screws and 3M 5200 marine sealant. around the screw/bolt holes.
Speaking of safety, wear your PFD (life jacket) at all times in that boat. 12' boats can be very unstable and tippy and I know you want to have many fishing trips with your son.
Rum, wenches, and song... just another day on my boat.
