Low 1648 small leak
golden ghost
Low 1648 small leak
Post by golden ghost »
I have a leak where the bottom meets the side. Right at the seam. Any thoughts of an easy fix. Thanks.
Ictalurus
Low 1648 small leak
Post by Ictalurus »
golden ghost wrote: Any thoughts of an easy fix.
Take it to a welder.
McAwful
Low 1648 small leak
Post by McAwful »
yep,..I wouldn't personally trust it to JB Marine weld or another sealant. I'd have it welded.
1999 Weldbilt 16
2002 Honda BF40
MinnKota Riptide 55
jigngrub
Low 1648 small leak
Post by jigngrub »
If it's a riveted boat I'd go with Gluvit or Coat-it.
If it's welded, take it to a welder.
If it's a riveted boat and you weld a seam you'll end up burning the gasket in between the 2 pieces of metal.
Rum, wenches, and song... just another day on my boat.
MrSimon
Low 1648 small leak
Post by MrSimon »
jigngrub wrote:If it's a riveted boat and you weld a seam you'll end up burning the gasket in between the 2 pieces of metal.
This is interesting. I didn't know there was a gasket between the two pieces. I've disassembled a few riveted boats and found no gasket, but they were pretty old. If there is a gasket and you weld it, I'd think there would no longer be a need for the gasket since the weld essentially makes the two pieces into one piece, eliminating the potential for leaking.
It would be good to see a picture of the crack in question.
Pics and videos of my past fishing trips: https://www.tinboattravels.com
acabtp
Low 1648 small leak
Post by acabtp »
most riveted boats do not have the gasket he is talking about
New Project - Duranautic DN-16
Primary Boat - 14' Starcraft V
Other Boat - 14' Sears Jon
In My Travels
Ictalurus
Low 1648 small leak
Post by Ictalurus »
My boat is riveted, but where the side meets the bottom I'm pretty sure that is welded.
kfa4303
Low 1648 small leak
Post by kfa4303 »
Depending on the size of the leak, you could coat it along with the rest of the interior seams with Gluv-it, or Coat-it which are both spreadable 2-part epoxies that dry tough, but flexible. Being and epoxy, it does require UV protection so you'll need to paint over after it cures fully and/or install some decks to protect it. West Marine usually sells it by the gallon, or 1/2 gallon. It can also be used to seal any wood you may have on the boat including the decks and transom. You may also be able to use a Marine putty epoxy to stop the leak, but it dries very hard and may crack in the future as the hull flexes. 3M 5200 and good ol JB weld are also some pretty amazing stuff for very small leaks.
