Hunter's Specialties Paint Camo Paint
Backslider
Central Idaho
Have any of you ever used Hunter's Specialties camo paint? I brush-painted my aluminum boat with the marsh grass color (2 coats, primed with a latex aluminium primer). It's cured for a week and is still sort of soft (I can dent it with my thumb nail) and it scratches pretty easy. Does this stuff ever cure out, or is it going to wear off pretty quick?
might be the primer, latex primer doesn't get as hard as regular primers. i sprayed the fenders of my trailer with the same paint i used on my boat. on the boat (self etching primer underneath) it is rock hard. on the trailer fenders i had to use latex based primer because they are galvanized and it is not nearly as hard of a finish, even though it was from the same batches of paint.
