Rippen Lips
Im planning on building a live well into the middle bench seat of my 1542 boat and I have a few questions.
The top hole in the end of the well will be the fill/aerator and the lower hole a overflow, The fill hole will be connected to a pump/timer pulling fresh water in through the transom.
My question is about the overflow. I also plan plumbing it out the transom. Does it have to exit the transom above the water line ?
Also Im putting a drain in the bottom of the live well. Where should it exit the boat ?
I may have this all wrong and need some expert advice. My goal is to be continuously bring fresh water into the live well as it gets very hot down here in Se Arkansas.
Thanks in advance for your input.
Jon
Jon
